Cisco Prime 1.3 Managed with warnings
wim_depauw
We are working with Cisco Prime 1.3 and have the problem that the devices are in the stated " Managed with warnings" . Some devices don't show the IOS version and some do.
The SNMP and telnet parameters are correct and when I delete the device  the IOS version is correctly shown although I still get the message " managed with warnings". After this  rediscovery it fails on the policyapp feature and feature_discovery_model feature.
The router is a Cisco 881 3G and is supported by Prime 1.3
Did anybody have this  problem also ?
gr
Wim
try installing the  latest 1.3.1 patch and see how it works
Thanks-
Afroz
[Do rate the useful post]
Thanks- Afroz [Do rate the useful post] ****Ratings Encourages Contributors ****
12 Replies 12
skelley5000
I have the same issue and I have also patched Prime with the patch...hopefully someone has some helpful hints? also mine issues are with C6K's, some work fine and some get this message...
Hi ,
Have you tried Deleting and re-adding the device ? If not then tried it once..
Check ACL ?
Check if you are using any special characters in the Community string , if there is any then create a new community string and test the things..
Lastly are you using any login Custom prompts on the device ?
if yes then follow the below steps:
You can configure custom username prompts using the following procedure:
1. Login to the PI CLI through SSH or console and enter the OS prompt by entering 'root'.
You can set the password for root user with the "root_enable" command.
2. Once on the Linux prompt, edit "/opt/CSCOncs/conf/usernameExpect.conf" add in a new
line with your specific username prompt, such as "username:".
3. Save & restart the services.
Hope above information will help
Thanks-
Afroz
Hi ,
Follow all the mentioned steps in this thread, I hope that will take care of your issue as well.
Thanks-
Afroz
wim_depauw
Adding and deleting  partially helps. When I delete the device it comes back with the IOS but is still in the state " managed with warnings" .
ACL's are ok , and I use a normal community string.
We have a banner on the router but the username and password prompt is still the same
tx
gr
wim
Is the credentials status is ok or  Failed ?
wim_depauw
credential status  is ok  but it fails on
share the output of  "show crypto ?"
wim_depauw
I tried with telnet and SSH and it gives the same result . Hereby the output of the show crypto ?
I don't understand what it has  to do with the problems that I have ....  Can you clarify ?
XXXX-R01#sho crypto ?
  call             Show crypto call admission info
  ctcp             cTCP connections
  datapath         Data Path
  debug-condition  Debug Condition filters
  dynamic-map      Crypto map templates
  eli              Encryption Layer Interface
  engine           Show crypto engine info
  entropy          Entropy sources
  gdoi             Show crypto gdoi
  identity         Show crypto identity list
  ikev2            Shows ikev2 info
  ipsec            Show IPSEC policy
  isakmp           Show ISAKMP
  key              Show long term public keys
  map              Crypto maps
  mib              Show Crypto-related MIB Parameters
  optional         Optional Encryption Status
  pki              Show PKI
  route            Show crypto VPN routes
  ruleset          Show crypto rules on outgoing packets
  session          Show crypto sessions (tunnels)
  sockets          Secure Socket Information
  tech-support     Displays relevant crypto information
  |                Output modifiers
XXXXX-R01#sho crypto
symptoms looks like this bug
PI reports " Managed Discoverywith Warnings" with ISR Device
CSCue02902
wim_depauw
I can't see the bug ( not enough permissions)  . Is it resolved in Prime 1.4 ?
Thanks-
Afroz
I installed the  latest patch and now it is working almost fine.  I needed to delete the device and did a bulk import again. With SSH it wasn't working but I tried again with telnet and now it is fine.
Tx for the quick assistance
