01-09-2015 09:53 AM
Dear Experts,
Kindly confirm is it possible to take the configuration back of a particular devices and get the output of the any cisco device(router/Switch) from Cisco Prme 2.1
Reagrds
TD
01-09-2015 02:59 PM
Do you mean create configuration backups?
If so, that's supported for the devices listed on the Compatibility page for PI.
I'm not sure what you mean about output.
01-09-2015 07:30 PM
Hi Marvin,
Thanks for the support..
I need to take the configuration back of the device.. that Output i meant in the above query
TD
