Cisco Prime 3.5: can not start DB
Netzwerker
Hi guys,
I want to install cisco prime 3.5 over esxi 5.5 but I got this error with "ncs status"
# ncs status
Health Monitor is running, with an error. ( [Role] Primary [State] HA not Configured )
initHealthMonitor(): can not start DB
Database server is stopped
FTP Service is running
TFTP Service is running
Matlab Server is running
Matlab Server Instance 1 is running
Matlab Server Instance 2 is running
Matlab Server Instance 3 is running
NMS Server is stopped.
SAM Daemon is stopped.
DA Daemon is stopped.
WSA service is stopped.
wsa apache httpd is stopped.
Compliance engine is not running
I cannot type " ncs db reinit" (I don't have db argument after ncs command)
it seems that the database service wasn't installed.
I tried with ncs stop and ncs start but always the same error!!
Help please
9 Replies 9
you better check below thread.
https://community.cisco.com/t5/network-management/cisco-prime-health-monitor-error/td-p/3377501
mark this as answer and rate if this solved your concern
Good luck
KB
Good luck
KB
Thank you for your answer But:
I mentionned that I when I type " #ncs ? " , il don't find "db" !
it means that "ncs db reinit" doesn't exist for me.
I am afraid a complete reinstallation is your only option...
I did it more than one time but the same thing!
When the VM is installing... it should shows me "running database cloning script..." and "running database creation script..." but this steps doesn't exist in the installation in my case.
I tried to install it in another ESXI and it's ok ! it's working.
So it can be caused by the ESXI hardware?
Which ESXI hardware does this work on, and which does it NOT work on ?
It's working on the ESXI 5.5 of our company but not on the customer's ESXI which is 5.5 also.
 - Please note that the in the mentioned command-example the intended command is ncs db reinit  without the prepending #
 M.
-- Let everything happen to you
       Beauty and terror
      Just keep going
       No feeling is final
Reiner Maria Rilke (1899)
Yes I know ! "#" means the cli
 - Where you connected with a user with all admin-privileges (?) , it is advised to  use the default local admin or root account , when you need the database-reinit command,
 M.
       Beauty and terror
      Just keep going
       No feeling is final
