Cisco Prime 3.8 and 3.9 Netflow dat now showing
Adnan Khan
Level 4
Level 4
Cisco Prime 3.8 and 3.9 Netflow dat now showing. Can  anyone assist how enable Netflow on Cisco Prime?
8 Replies 8
marce1000
 - Ref : https://www.cisco.com/c/en/us/td/docs/net_mgmt/prime/infrastructure/3-2/admin/guide/bk_CiscoPrimeInfastructure_3_2_AdminGuide/bk_CiscoPrimeInfastructure_3_2_AdminGuide_chapter_01.html#con_1055426 , do you have a Assurance and or Collector license ?
 M.
Hi Marce,
Yes, I have Assurance license
How I can setup Prime to see Netflow data from devices?
Administration > Licenses and Software Updates > Licenses > Assurance Licenses
Unlicensed Devices 0 | License Remaining 200
Net-flow is configured on device and device also added in Prime.
 - Ref : https://www.cisco.com/c/en/us/td/docs/net_mgmt/prime/infrastructure/3-8/user/guide/bk_CiscoPrimeInfrastructure_3_8_0_UserGuide/set_up_network_monitoring.html?bookSearch=true#con_1075844 . look at Table 1 , verify if device is supported and also look at column Netflow Configuration , verify settings accordingly.
 M.
I have change Netflow port UDP 9991 and i can see under (Services / Application Visibility... / Data Cources
But in Administration > Licenses and Software Updates > Licenses > Assurance Licenses
still cant see device to Add
 - I am not sure if I understand you here , you may verify if your devices are sending Netflow data by trying a free netflow collector as an alternative to Prime such as : https://www.pcwdld.com/go/solarwindsnetflow-traffic-analyzer-learn-more/l/list/ , that would be an additional sanity check so to speak.
 M.
I can see devices in Assurance license thanks. One more thing under Dashboard / Performance -> Interfaces -> Interface Tx and Rx Utilization. It shows as below instead of interface Tx and Rx
Check if SNMP Polling is enabled
