07-19-2022 01:49 AM
Is there a way to easily clear all alerts in Prime. I'm working at a company that has thousands of historical alerts and i need to clear them down to have a fresh slate to work with. You can only select 500 in the GUI so clearing 500 at a time will take forever, need a better way!
Solved! Go to Solution.
07-19-2022 07:23 AM
I think you can directly edit the Prime database. Have a look at the link below:
https://ralpholsen.dk/2016/02/18/350-000-alarms-in-prime-infrastructure/
07-19-2022 07:23 AM
