Showing results forĀ
Search instead forĀ
Did you mean:Ā
cisco prime graceful shutdown
elite2010
Level 3
Level 3
What is the successful procedure to shutdown cisco prime gracefully (Appliance)
Enter on Shell mode and password, (command shell), then you enter the shutdown command.
Marvin Rhoads
The part that's important is the server application and associated processes like the underlying Oracle database.
You can stop all of that with the cli command "ncs stop". Once that command has completed shutting down the application you can safely power off the server.
If you're adamant about shutting down the Linux OS gracefully as well, the switch to the root shell from the cli and do a normal Liunx "shutdown" command.
There is also the halt command at the ncs prompt. I'm not sure if that's available in the appliance or not. I suspect it is.
itasuporte
Since I am using virtual machine version of Prime Infrastructure 3.5:
1) Using a browser navigate to vmware esxi webconsole ip,
2) click in the virtual machine console and log as admin
3) under cli prime/admin#, type the cli command:
ncs stop
4) wait about 5 minutes, until show the message "completed shutdown of all services"
5) type: halt
6) Save the current ade-os running configuration (yes/no) [yes]? <enter>
7) Continue with shutdown ? [y/n]  <y>
8) Wait a little, and it“s done
