Cisco Prime HA upgrade from 3.0 to 3.1
saleem pc
I hope some one can guide me on the upgrade process.
We have Cisco Prime 3.0.0.0.78 on UCS appliance PI-UCS-APL-K9 and plan to upgrade to 3.1.7
I read, HA has to be removed first before upgrade, It would be great if some one can guide on detailed procedure of upgrade and back up.
marce1000
 https://www.cisco.com/c/en/us/td/docs/net_mgmt/prime/infrastructure/3-1/administrator/guide/PIAdminBook/config_HA.pdf
             Read the section : Removing HA During Upgrade
M.
Thanks for the info,
is it must to remove the HA before upgrade from 3.0 to 3.1.7 ?. is it direct upgrade ?.
Thanks a lot in advance
