Cisco Prime help...
aj.king
I am relatively new to Cisco, and was handed Cisco Prime to basically learn on my own.  So please bear with me if I am missing something obvious.  I have the Archive Summary Report, and it shows 26 devices that failed to backup.  Basically the lines read as follows
Device Name     : Config Type      : File Type      : Accessed at : Description
Whatever          :  PRIMARY        : RUNNING     : Aug 6, 2012 : SSH: Failed to establish SSH connection to xx.xx.xxx.xx - Cause: Authentication failed on device 3 times.  TELNET: Failed to establish TELNET connection to xx.xx.xxx.xx - Cause: Connection timed out.
All lines are the same outside of the last statement varying from timed out to Connection refused.
Config types vary between PRIMARY & VLAN
File types vary between RUNNING & STARTUP
When I acess the device in prime and use the Reachability status I get the following.
Since SSHv2 is setup shouldn't Telnet, SSHv1 automatically be removed from the report as failed?  What am I missing?  Are these devices actually getting connection or not?
Duong Nguyen
I believe you have to remove those from the checklist yourself.
Check under DCR verification settings
