01-03-2017 04:03 AM
Hello!
I have a Cisco Prime Infra 3.1.0.0.132 with all updates installed. After restarting the ncs has not started.
If I try to start manually, I see:
setup of pnp failed please see the /var/KickStart/install/setup.log
FATAL ERROR: Could not start display service
setup.log
/bin/cp: writing `/var/KickStart/install/ks_env_tmp.in': No space left on device
"/bin/cp -f /var/KickStart/install/ks_env.sh /var/KickStart/install/ks_env_tmp.in" failed
cleanning up.......
execute (rm -f /var/KickStart/install/ks_env_tmp.sh)
execute (rm -f /var/KickStart/install/ks_env_tmp.in)
execute (rm -f /var/KickStart/install/ncsenv_tmp.sh)
execute (rm -f /var/KickStart/install/ncsenv_tmp.in)
execute (rm -f /tmp/ncsenv.tmp)
cleanning up done.......
"/bin/cp -f /var/KickStart/install/ks_env.sh /var/KickStart/install/ks_enPlug and Play Gateway is success
fully disabled
Setup failure /ks_env.sh or /ncsenv.sh file not available
/opt/CSCOlumos/KickStart/bin/ncsconfigure.sh: line 216: $PNP_SETUP_LOG: ambiguous redirect
I found this
/dev/mapper/smosvg-varvol
4031680 4031680 0 100% /var
ncs cleanup did not help
What to do?
Solved! Go to Solution.
01-05-2017 06:16 AM
SSH Login as admin
shell
sudo su -
cd /var/cache/logwatch/
rm -rf logwatch.*
vi /usr/share/logwatch/default.conf/logwatch.conf
remove "# " from line "DailyReport = No"
:wq
check with:
df -h
and voila:
3.9G 242M 3.5G 7% /var
thx for the help
Other interresting links to this topic:
http://www.cisco.com/c/en/us/support/docs/cloud-systems-management/prime-infrastructure/200760-CLI-Root-User-Password-Recovery-Process.html
http://unix.stackexchange.com/questions/42857/how-to-extend-centos-5-partition-on-vmware#42910
01-03-2017 03:20 PM
Hello
I get the same error message after installing “PI 3.1.4 Update 01” via GUI.
A restore attempt of the application did not solve the problem.
INFO: Restore completed successfully.
The problem is below the application on the level of the unix os. But without a root account there is nothing to fix.
The admin account has not enough permissions to delete files from the folder “/dev/mapper/smosvg-varvol”
Does anyone has a solution?
thx
Cisco Prime Infrastructure
Version : 3.1.0
Build : 3.1.0.0.132
Critical Fixes:
PI 3.1.4 Maintenance Release ( 4.0.0 )
3.9G 3.9G 0 100% /var
01-05-2017 03:58 AM
- You should be able to get to a root-based shell, after being logged in with 'admin'; following
# shell
# sudo -s
M.
01-05-2017 04:45 AM
And what to do?
01-05-2017 06:16 AM
SSH Login as admin
shell
sudo su -
rm -rf logwatch.*
:wq
check with:
df -h
and voila:
thx for the help
01-06-2017 03:20 AM
Reichmuth I did not try your method.
I have found that is not installed PI_3_1_4-1.0.38.ubf and reinstall the server.
It installed properly PI_3_1_4_update_01-1.0.11.ubf
Thank you all!
02-15-2017 10:21 PM
I wish I found this thread sooner. I ended up having to delete the /var/cache/logwatch files as well to make room for ncs to start after a power failure. Thanks for the information.
03-24-2017 08:22 AM
Thank you for your threat. It helped at least to get the filesystem done in terms of working.
best regards
Robert
11-23-2018 03:59 PM
Thanks for the post. This helped us get our server back up and running after a reboot.
08-20-2019 10:39 PM - edited 08-20-2019 10:42 PM
The logwatch.conf file nor directory exists in PI 3.5 :(
Searching now for an alternative solution for a full /var.
Issue is the /var/log/wtmp file, which uses nearly 80% of the partition.
[edit]
And I've already found a (temporary?) solution:
#enter shell: shell #get root sudo su - #write an empty new wtmp file (this can take a minute) cat /dev/null > /var/log/wtmp #In my case the messages file was also already > 500 MB, I'm not sure yet if I should also clean it. wtmp file was 2.7 GB though.
08-20-2019 11:26 PM - edited 08-20-2019 11:30 PM
Ok, fixed it (probably until the next patch/major release) by editing the /etc/logrotate.d/syslog file (plus all the others for good measure, where I also received an error message). I added the line ' su prime gadmin '
[root@cpi1 logrotate.d]# vi syslog /var/log/cron /var/log/maillog /var/log/messages /var/log/secure /var/log/spooler { su prime gadmin missingok sharedscripts postrotate /bin/kill -HUP `cat /var/run/syslogd.pid 2> /dev/null` 2> /dev/null || true endscript } # To safe enter :wq # It will logrotate all the files mentioned in this file within the next 24 hours automatically # To manually rotate enter 'run-parts /etc/cron.daily/'
Please note, this will NOT cleanup the used space, as the files will not be compressed nor removed (they will be kept for 1-4 weeks). So if you need space now, remove the files with a .1, .2, .3 or .4 ending after logrotate has run.
Please also note, logrotate can only successfully run if there is at least some space left. If the partition is completely full, clean the wtmp file first (or any other large file).
08-20-2019 11:39 PM
One more little addition, to rotate wtmp and btmp, edit the /etc/logrotate.conf to:
# other lines removed /var/log/wtmp { su root guser monthly create 0640 root guser rotate 1 } /var/log/btmp { su root guser weekly create 0600 root guser rotate 4 }
# other lines removed … … .
