Cisco Prime Infra got problem with API
Yun Ching Angela Lin
customer use following command to collect data from Prime Infra (version 2.1) but got error message.
is it because our API syntax error or we need to upgrade PI version ?
curl -k -u root:password 'https://10.10.1.100/webacs/api/v1/data/ClientDetails.json?.full=true&.firstResult=0&.maxResults=500'
Result:
{"errorDocument":{"httpResponseCode":500,"httpMethod":"GET","message":"Exception while invoking valueOf method 'getEnum' of enumeration class 'class com.cisco.ncs.nbi.client.ClientProtocolEnum'; nested exception is org.hibernate.HibernateException: Exception while invoking valueOf method 'getEnum' of enumeration class 'class com.cisco.ncs.nbi.client.ClientProtocolEnum'","exception":"org.springframework.orm.hibernate3.HibernateSystemException: Exception while invoking valueOf method 'getEnum' of enumeration class 'class com.cisco.ncs.nbi.client.ClientProtocolEnum'; nested exception is org.hibernate.HibernateException: Exception while invoking valueOf method 'getEnum' of enumeration class 'class com.cisco.ncs.nbi.client.ClientProtocolEnum'","uriPath":"data\/ClientDetails","queryParams":"{.full=[true], .firstResult=[0], .maxResults=[500]}"}}
Mark Elsen
 - You should at least consider upgrading because PI2.x is very old , you may for instance build a small test installation with the latest version  of Prime and then verify this issue again.
 M.
