FastEthernet0/0 26304304 input errors - need help
Hello all, need help with some problem on eth 0/0 i'ts burn my ...s averyday. (26304304 input errors)
Connection stable, no problems with physycs level, no problem with upload and download data, but I still want to beat this problem. Sometimes messages come from zabbix, that the problem has been successfully resolved, but in just a couple of minutes, it appears again. I was clear counters, but it's can't help me issue this troble. I reset error counters, but this is only a temporary solution.
FastEthernet0/0 is up, line protocol is up
Hardware is MV96340 Ethernet, address is ---------------
MTU 1500 bytes, BW 100000 Kbit/sec, DLY 100 usec,
reliability 255/255, txload 13/255, rxload 2/255
Encapsulation 802.1Q Virtual LAN, Vlan ID 1., loopback not set
Keepalive set (10 sec)
Full-duplex, 100Mb/s, 100BaseTX/FX
Last input 00:00:00, output 00:00:00, output hang never
Input queue: 0/75/144530/0 (size/max/drops/flushes); Total output drops: 0
Queueing strategy: fifo
Output queue: 0/40 (size/max)
5 minute input rate 1082000 bits/sec, 341 packets/sec
5 minute output rate 5189000 bits/sec, 603 packets/sec
3861806175 packets input, 3160733486 bytes
Received 4508298 broadcasts (0 IP multicasts)
0 runts, 0 giants, 23072 throttles
26304304 input errors, 0 CRC, 0 frame, 0 overrun, 26304304 ignored
0 watchdog
3408592805 packets output, 1465598348 bytes, 0 underruns
0 output errors, 0 collisions, 1 interface resets
1226088 unknown protocol drops
1 lost carrier, 0 no carrier
Leo Laohoo
Is the port's speed and duplex hard-coded?
Post the complete output to the following command:
sh controll e f0/0
2811-router#sh controll fastethernet 0/0
Interface FastEthernet0/0
Hardware is MV96340
HWIDB: 497ECB98, INSTANCE: 497EDD48, FASTSEND: 45139FAC, MCI_INDEX: 0
Aggregate MIB Counters
Rx Good Bytes: 2135522001569323 Rx Good Frames: 4033275991
Rx Bad Bytes: 0 Rx Bad Frames: 0
Rx Broadcast Frames: 2691861 Rx Multicast Frames: 20380138
Tx Good Bytes: 2724797716001006 Tx Good Frames: 3620237697
Tx Broadcast Frames: 63 Tx Multicast Frames: 749622
Rx+Tx Min-64B Frames: 1630268703 Rx+Tx 65-127B Frames: 2916427615
Rx+Tx 128-255B Frames: 1300209559 Rx+Tx 256-511B Frames: 771812766
Rx+Tx 512-1023B Frames: 1285566127 Rx+Tx 1024-MaxB Frames: 4044196214
Rx Unrecog MAC Ctrl Frames: 0
Rx Good FC Frames: 0 Rx Bad FC Frames: 0
Rx Undersize Frames: 0 Rx Fragment Frames: 0
Rx Oversize Frames: 0 Rx Jabber Frames: 0
Rx MAC Errors: 0 Rx Bad CRCs: 0
Tx Collisions: 0 Tx Late Collisions: 0
PHY Registers
Register 0x00: 1000 782D 0040 61E4 01E1 41E1 0005 2001
Register 0x08: 0000 xxxx xxxx xxxx xxxx xxxx xxxx xxxx
Register 0x10: 1000 0300 0000 0000 0200 0063 0300 0000
Register 0x18: 003B 851F 9F00 048E 082B 0000 80A0 000B
PHY Control (0x00):
AUTONEG_EN
PHY Status (0x01):
AUTONEG_DONE LINK_UP
Auto-Negotiation Advertisement (0x04):
100FD 100HD 10FD 10HD
Link Partner Ability (0x05):
Serial Management Interface Registers (0xB4002000)
PHYAR = 0x00002841 SMIR = 0x0FE1000B
EUDAR = 0x00000000 EUDIDR = 0x000000E0 EUICR = 0x00000010
EUIMR = 0x00000000 EUEAR = 0x00000000 EUIAER = 0x00000000
BAR0 = 0x00000E00 SR0 = 0x0FFF0000
BAR1 = 0x00000000 SR1 = 0x00000000
BAR2 = 0x00000000 SR2 = 0x00000000
BAR3 = 0x00000000 SR3 = 0x00000000
BAR4 = 0x00000000 SR4 = 0x00000000
BAR5 = 0x00000000 SR5 = 0x00000000
HARR0 = 0x00000000 HARR1 = 0x00000000
HARR2 = 0x00000000 HARR3 = 0x00000000
BARER = 0x0000003E EPAPR0 = 0x00000003 EPAPR1 = 0x00000003
Port Control Registers (0xB4002400)
PCR = 0x00000000 PCER = 0x00000000 MII = 0x00218823
GMII = 0x00000006 VLANET = 0x00008100 MACLO = 0x0000ED48
MACHI = 0x001EF79D SDCR = 0x01000009 DSCP0 = 0x00000000
DSCP1 = 0x00000000 DSCP2 = 0x00000000 DSCP3 = 0x00000000
DSCP4 = 0x00000000 DSCP5 = 0x00000000 DSCP6 = 0x00000000
PSCR = 0x000A060B VPT2P = 0x00000000 PSR = 0x00000426
TQCR = 0x0000FE00 TQFPC = 0x000000FF PTTBRC = 0x000003FF
MTU = 0x00000006 PMTBS = 0x0000FFFF ICR = 0x00000000
ICER = 0x00000000 IMR = 0xFFFFFFFF IMER = 0xFFFFFFFF
PRFUTR = 0x00000008 PTFUTR = 0x00000000 PMFSR = 0x00000040
PDFC = 0x00000000 POFC = 0x00000000 EUIAER = 0x00000000
CRDP0 = 0x0F5BDE50 CRDP1 = 0x00000000 CRDP2 = 0x00000000
CRDP3 = 0x00000000 CRDP4 = 0x00000000 CRDP5 = 0x00000000
CRDP6 = 0x00000000 CRDP7 = 0x00000000 RQCR = 0x0003FE01
TCSDP = 0x0F5BEC60 TCQDP0 = 0x0F5BEC60 TCQDP1 = 0x00000000
TCQDP2 = 0x00000000 TCQDP3 = 0x00000000 TCQDP4 = 0x00000000
TCQDP5 = 0x00000000 TCQDP6 = 0x00000000 TCQDP7 = 0x00000000
TQTBCTR0 = 0x0001D803 TQTBCFG0 = 0x03FFFFFF TQARCFG0 = 0x00000006
TQTBCTR1 = 0x1B9BFFCE TQTBCFG1 = 0x03FFFFFF TQARCFG1 = 0x00000006
TQTBCTR2 = 0x154AC3C9 TQTBCFG2 = 0x03FFFFFF TQARCFG2 = 0x00000006
TQTBCTR3 = 0x136CC8FC TQTBCFG3 = 0x03FFFFFF TQARCFG3 = 0x00000006
TQTBCTR4 = 0x2C6EEFFF TQTBCFG4 = 0x03FFFFFF TQARCFG4 = 0x00000006
TQTBCTR5 = 0x063CCF0A TQTBCFG5 = 0x03FFFFFF TQARCFG5 = 0x00000006
TQTBCTR6 = 0x337FE7E6 TQTBCFG6 = 0x03FFFFFF TQARCFG6 = 0x00000006
TQTBCTR7 = 0x1BF6CC8E TQTBCFG7 = 0x03FFFFFF TQARCFG7 = 0x00000006
PTTBC = 0x3FFFF3F3
Hardware MAC Address Filters
Unicast Filter
[00-03] = 0x00000000 0x00000000 0x00000001 0x00000000
Special Multicast Filter
[00-03] = 0x00000000 0x00000000 0x00000000 0x00000000
[04-07] = 0x00000000 0x00000000 0x00000000 0x00000000
[08-11] = 0x00000000 0x00000000 0x00000000 0x00000000
[12-15] = 0x00000000 0x00000000 0x00000000 0x00000000
[16-19] = 0x00000000 0x00000000 0x00000000 0x00000000
[20-23] = 0x00000000 0x00000000 0x00000000 0x00000000
[24-27] = 0x00000000 0x00000000 0x00000000 0x00000000
[28-31] = 0x00000000 0x00000000 0x00000000 0x00000000
[32-35] = 0x00000000 0x00000000 0x00000000 0x00000000
[36-39] = 0x00000000 0x00000000 0x00000000 0x00000000
[40-43] = 0x00000000 0x00000000 0x00000000 0x00000000
[44-47] = 0x00000000 0x00000000 0x00000000 0x00000000
[48-51] = 0x00000000 0x00000000 0x00000000 0x00000000
[52-55] = 0x00000000 0x00000000 0x00000000 0x00000000
[56-59] = 0x00000000 0x00000000 0x00000000 0x00000000
[60-63] = 0x00000000 0x00000000 0x00000000 0x00000000
Other Multicast Filter
[08-11] = 0x00000000 0x00000000 0x00000000 0x00000100
[12-15] = 0x00000000 0x00010000 0x00000000 0x00000000
[48-51] = 0x00000000 0x00000000 0x00000000 0x00000100
Software MAC Address Filter (hash:length/addr/mask/hits)
0x000: 0 ffff.ffff.ffff 0000.0000.0000 2691378
0x0BF: 0 001e.f79d.ed48 0000.0000.0000 0
0x0C0: 0 0180.c200.0002 0000.0000.0000 0
0x0C0: 1 0100.0ccc.cccc 0000.0000.0000 1856437
0x0C5: 0 0180.c200.0007 0000.0000.0000 0
Software filtered frames: 0
Unicast overflow mode: 0
Multicast overflow mode: 1
Promiscuous mode: 0
Rx Rings
Rx Ring 0 Rx Ring 1
- size = 128 - size = 0
- head = 93 - head = 0
- shadow = 0x497EE238 - shadow = 0x00000000
- ring = 0x0F5BD840 - ring = 0x00000000
- ring_malloc = 0x3F5BD840 - ring_malloc = 0x00000000
Rx Ring 2 Rx Ring 3
- size = 0 - size = 0
- head = 0 - head = 0
- shadow = 0x00000000 - shadow = 0x00000000
- ring = 0x00000000 - ring = 0x00000000
- ring_malloc = 0x00000000 - ring_malloc = 0x00000000
Rx Ring 4 Rx Ring 5
Rx Ring 6 Rx Ring 7
Tx Rings
Tx Ring 0 Tx Ring 1
- size = 256 - size = 0
- head = 184 - head = 0
- tail = 184 - tail = 0
- usedtxds = 0 - usedtxds = 0
- framecnt = 0 - framecnt = 0
- shadow = 0x497EE46C - shadow = 0x00000000
- ring = 0x0F5BE080 - ring = 0x00000000
- ring_malloc = 0x3F5BE080 - ring_malloc = 0x00000000
Tx Ring 2 Tx Ring 3
- tail = 0 - tail = 0
Tx Ring 4 Tx Ring 5
Tx Ring 6 Tx Ring 7
Port Stopped: N
Is FastEthernet 0/0 port hard-coded with duplex and speed settings?
If it is, why?
