Issue with CONFIG-COPY-MIB
little-fingers
Hello community,
I am trying to use the config copy mib for conf updates. While it works great using tftp, I have an issue with scp and I fail to see where I am wrong. From CLI, both TFTP and SCP do work as expected.
Hardware is 2960X running 15.0(2)EX5
Working TFTP test:
ccopy@syslog:~ % cat /tftpboot/test.conf
int lo6
description test-conf-copy-mib-TFTP
end
ccopy@syslog:~ % ./confcopy tftp
CISCO-CONFIG-COPY-MIB::ccCopyProtocol.88912 = INTEGER: tftp(1)
CISCO-CONFIG-COPY-MIB::ccCopySourceFileType.88912 = INTEGER: networkFile(1)
CISCO-CONFIG-COPY-MIB::ccCopyDestFileType.88912 = INTEGER: runningConfig(4)
CISCO-CONFIG-COPY-MIB::ccCopyServerAddress.88912 = IpAddress: A.B.C.D
CISCO-CONFIG-COPY-MIB::ccCopyFileName.88912 = STRING: test.conf
CISCO-CONFIG-COPY-MIB::ccCopyUserName.88912 = STRING: ccopy
CISCO-CONFIG-COPY-MIB::ccCopyUserPassword.88912 = STRING:
CISCO-CONFIG-COPY-MIB::ccCopyNotificationOnCompletion.88912 = INTEGER: false(2)
CISCO-CONFIG-COPY-MIB::ccCopyState.88912 = INTEGER: successful(3)
CISCO-CONFIG-COPY-MIB::ccCopyTimeStarted.88912 = Timeticks: (1728626846) 200 days, 1:44:28.46
CISCO-CONFIG-COPY-MIB::ccCopyTimeCompleted.88912 = Timeticks: (1728627647) 200 days, 1:44:36.47
CISCO-CONFIG-COPY-MIB::ccCopyEntryRowStatus.88912 = INTEGER: active(1)
CISCO-CONFIG-COPY-MIB::ccCopyServerAddressType.88912 = INTEGER: ipv4(1)
CISCO-CONFIG-COPY-MIB::ccCopyServerAddressRev1.88912 = STRING: "A.B.C.D"
CISCO-CONFIG-COPY-MIB::ccCopyEntryRowStatus.88912 = INTEGER: destroy(6)
ccopy@syslog:~ % snmpwalk -v2c -c c0mUn1tY X.Y.Z.T ifName | grep Lo
IF-MIB::ifName.14067 = STRING: Lo6
ccopy@syslog:~ % snmpwalk -v2c -c c0mUn1tY X.Y.Z.T ifAlias | grep copy-mib
IF-MIB::ifAlias.14067 = STRING: test-conf-copy-mib-TFTP
log on switch:
Jun 26 12:46:29.328: %SYS-5-CONFIG_I: Configured from tftp://A.B.C.D/test.conf by console
Jun 26 12:46:31.328: %LINK-3-UPDOWN: Interface Loopback6, changed state to up
Jun 26 12:46:32.338: %LINEPROTO-5-UPDOWN: Line protocol on Interface Loopback6, changed state to up
Doing the same with SCP ends in error. SCP transfer to running works with the CLI
ccopy@syslog:~ % cat test.conf
int lo7
description test-conf-copy-mib-SCP
end
ccopy@syslog:~ % ./confcopy scp
CISCO-CONFIG-COPY-MIB::ccCopyProtocol.88971 = INTEGER: scp(4)
CISCO-CONFIG-COPY-MIB::ccCopySourceFileType.88971 = INTEGER: networkFile(1)
CISCO-CONFIG-COPY-MIB::ccCopyDestFileType.88971 = INTEGER: runningConfig(4)
CISCO-CONFIG-COPY-MIB::ccCopyServerAddress.88971 = IpAddress: A.B.C.D
CISCO-CONFIG-COPY-MIB::ccCopyFileName.88971 = STRING: test.conf
CISCO-CONFIG-COPY-MIB::ccCopyUserName.88971 = STRING: ccopy
CISCO-CONFIG-COPY-MIB::ccCopyUserPassword.88971 = STRING:
CISCO-CONFIG-COPY-MIB::ccCopyNotificationOnCompletion.88971 = INTEGER: false(2)
CISCO-CONFIG-COPY-MIB::ccCopyState.88971 = INTEGER: failed(4) <<<<<<<<<<<<<<<<<<<<<<<<<<<<<
CISCO-CONFIG-COPY-MIB::ccCopyTimeStarted.88971 = Timeticks: (1728676853) 200 days, 1:52:48.53
CISCO-CONFIG-COPY-MIB::ccCopyTimeCompleted.88971 = Timeticks: (1728676869) 200 days, 1:52:48.69
CISCO-CONFIG-COPY-MIB::ccCopyFailCause.88971 = INTEGER: badFileName(2) <<<<<<<<<<<<<<<<<<<<
CISCO-CONFIG-COPY-MIB::ccCopyEntryRowStatus.88971 = INTEGER: active(1)
CISCO-CONFIG-COPY-MIB::ccCopyServerAddressType.88971 = INTEGER: ipv4(1)
CISCO-CONFIG-COPY-MIB::ccCopyServerAddressRev1.88971 = STRING: "A.B.C.D"
CISCO-CONFIG-COPY-MIB::ccCopyEntryRowStatus.88971 = INTEGER: destroy(6)
ccopy@syslog:~ %
SWITCH#sh int desc | i SCP
SWITCH#
SWITCH#copy scp://ccopy@A.B.C.D/test.conf running-config
Destination filename [running-config]?
Password for ccopy@syslog:
Sending file modes: C0644 47 test.conf
47 bytes copied in 6.407 secs (7 bytes/sec)
SWITCH#
Jun 26 12:55:54.439: %SYS-5-CONFIG_I: Configured from scp://ccopy@A.B.C.D/test.conf by cisco on vty0 (A.B.C.D)
Jun 26 12:55:55.443: %LINEPROTO-5-UPDOWN: Line protocol on Interface Loopback7, changed state to up
Lo7 up up test-conf-copy-mib-SCP
SWITCH#
Well... I am a bit puzzled. If someone can shed some light on this, it would be very appreciated :-)
2 Accepted Solutions
Mark Elsen
 - Check and or turn on verbose logging for the remote sshd-server, then see what is reported when  you try confcopy with the scp protocol
 M.
-- Let everything happen to you
       Beauty and terror
      Just keep going
       No feeling is final
Reiner Maria Rilke (1899)
Thanks for looking into this. Your suggestion directed me straight to the root cause: SSH authentication issue, the agent doesn't know about keyboard-interactive method. I had to enable the old builtin pwd auth mechanism.
For those not familiar with OpenSSH, it is option 'PasswordAuthentication=yes'
5 Replies 5
Mark Elsen
 M.
       Beauty and terror
      Just keep going
       No feeling is final
 - Good work !
 M.
       Beauty and terror
      Just keep going
       No feeling is final
Thanks Marce !
 - Please mark thread as resolved , not so much for myself but for those who browse subjects on the forum and or later indexing in search engines too.
 M.
       Beauty and terror
      Just keep going
       No feeling is final
