Cisco Prime Infrastructure 1.1
Vikas Gundu
Hi Team,
 I have a doubt for version PI-1.1.
PI 1.1 is installed on the VMware i.e. on the virtual platform
The customer has bought the following:
R-PI-1.1-K9 ------Cisco Prime Infrastructure 1.1
R-PI-1.1-100-K9-----Prime Infrastructure 1.1 Software - 100 Device Base Lic
L-PILMS42-100------------- Prime Infrastructure LMS 4.2 - 100 Device Base Lic
L-PINCS11-100------------- Prime Infrastructure NCS 1.1 - 100 Device Base Lic
L-PINCSW11-100---------- Prime Infrastructure NCS WAN 1.1 - 100 Device Base Lic
As it is the 1.1 there is no lifecycle and assurance licenses.
Currently L-PINCS11-100 is installed on the server.
How do I install L-PINCSW11-100 and L-PILMS42-100.
Can this both licenses be installed on the same server or do they need additional server.
Thanks in advance..
6 Replies 6
Vinod Arya
These are separate licenses. L-PINCSW11 is used for NCS whereas L-PILMS42-100 is applied on Ciscoworks LMS.
As PI 1.1 was the initial release where Cisco combined two individual monitoring applications : Network Control System (NCS) for wireless infrastructure and Ciscoworks LAN Management Solution (LMS) for wired infrastructure together, and hence has some issues with features and user experience. So Cisco gave additional licenses for NCS and LMS, for those customers who still wanted those applications separately.
You can use them if you want to use them separately.
-Thanks
Vinod
**Encourage Contributors. RATE Them.**
-Thanks Vinod **Rating Encourages contributors, and its really free. **
there is only 1 license has been installed. Customer wants remaining 2 licenses(L-PILMS42-100 &  L-PINCSW11-100) to be installed on the server.
Is it possible to install on same server??
Do you need additional server for it..
They are other applications, and need to be installed on new server's.
In short previously there was two applications :
NCS and LMS
Now:
NCS+LMS = CPI
All three of them have separate license.
-Thanks
Vinod
Thanks Vinod....
But still confused..:(
correct me if i'm wrong
On 1 server you need to install
and on 2nd server u need to install
Is it correct????
If you install PI 1.1 you need a base licence. You must have a single base license to run the software. The base license here is R-PI-1.1-K9.
After this you need a Device license which decides how many devices you can manage on your application. Here Device Base License is R-PI-1.1-100-K9 which is Cisco Prime Infrastructure 1.1 Software - 100 Device Base License.
So to run your Cisco Prime Infra 1.1 you need only these two licenses (more if you want to manage more that 100 device - using add-on license).
You can check CPI 1.1 License guide here.
So server 1 = CPI 1.1 :
Other Server's, if you want these applications:
1 for = NCS Application/software (L-PINCS11-100)
1 for Ciscoworks LMS application/software (L-PINCSW11-100)
-Thanks
Vinod
Thanks Vinod...
