05-02-2014 07:55 AM
Hi all,
I want to download Cisco Prime Infrastructure 1.2 OVA but I can't find it, there is just "Cisco Prime Infrastructure 1.2 Plug and Play for Virtual Appliance " . Is this the right OVA ?
Thanks for your help
BR
Aaziz
Solved! Go to Solution.
05-02-2014 08:35 AM
Hi Aaziz,
Unfortunately this download of this file is not available anymore on cisco.com site.
As an alternative, you can download PI 1.3 OVA, where you can find the same features and
interface:
http://software.cisco.com/download/release.html?mdfid=284652876&softwareid=284272932&relea
se=1.3&relind=AVAILABLE&rellifecycle=&reltype=all
Note: you can use the same license of PI 1.2 on PI 1.3
Thanks-
Afroz
***Ratings Encourages Contributors ***
05-02-2014 08:35 AM
Hi Aaziz,
interface:
Thanks-
Afroz
05-02-2014 12:47 PM
Hi Afroz,
Thank you for your reply, It helps me !
BR,
Aaziz
04-07-2015 02:39 AM
Hi Afroz,
is the license of PI 1.2 on PI 1.4 ok?
tks a lot.
