Cisco Prime Infrastructure 1.3 to 2.1
BrianEschen
I have a Cisco Prime Infrastructure version 1.3 virtual appliance and we have a new Prime Infrastructure version 2.1 virtual appliance set up. I would like to get the wireless information put into the new server. This includes the WLC and APs and then the campus maps and the location of each AP on the map Im not sure if the heat mapping is a feature of Prime or if I have to set that up too. But I would like the heat maps.
What would be the easiest way todo this?
Marvin Rhoads
Just carefully follow the upgrade guide to migrate your system from the old 1.3 server to the new 2.1 server. Everything should convey properly if you do that.
Marvin Rhoads
I cant open this link??
This is me error...
404 Page Not Found
The Page You Have Requested Is Not Available
http://www.cisco.com/c/en/us/td/docs/net_mgmt/prime/infrastructure/2-1/quickstart/guide/cpi_qsg.html#pgfId-78605
Are you logged in with a cisco.com (CCO ) userid? I just checked it and it works fine for me.
You can navigate down to it via:
HOME
I am not sure what was happening. I cleared my cache and it worked. Thanks for the help!
