cisco prime infrastructure 2.0 inventory SFP
Tiago Marques
hello,
anyone knows if it is possible with cisco prime infrastructure 2.0 create inventory to obtain data from SFP (serial number and model)?
thank you
AFROJ AHMAD
Hi ,
Can you try the below report and see if you are able to see the information , you are looking for
Report > Report Launch Pad > Device > Detailed Hardware
Thanks-
Afroz
***Ratings Encourages Contributors ****
Thanks- Afroz [Do rate the useful post] ****Ratings Encourages Contributors ****
does not work
I call the company that supports us and they get it using the tool :
cisco CSP collector
thnks
Tiago
