Cisco Prime Infrastructure 3.9 compliance mgt not apparing
Eric R. Jones
Level 4
Level 4
Hello all, please bare with me.
We were running Cisco Prime 3.7 and created a new Bare metal deployment for 3.9. Both installs are virtual, one was Express I believe and the new one is Professional, so we got the entire 1.2TB.
I used the 3.7 application backup to restore to the new 3.9 and it's working fine so far; However we didn't have Compliance Mgt enabled on the old but it should be enabled on the new build correct?
Or will it not be enabled because I'm using the old application restore?
I would think that wouldn't be the case since the ability to use this function is based on the current version and mode of choice.
ej
0 Replies 0
