01-15-2014 03:13 AM
Hi All,
Kindly I need to know what is the location of Archieved Configuration Backup that taken by PI (are they saved in a specific repo or what?) and how can I gather them automatically??
thanks
Best Regards.
01-15-2014 03:23 AM
Hi Mohamed,
https://supportforums.cisco.com/message/3975460#3975460
check the above thread ,this will answer your query..
Thanks-
Afroz
[Do rate the useful post]
01-15-2014 04:19 AM
thanks Afroz for your response
I checked it
does it mean this task cannot be done by PI as it is a bug in it?
if it is a bug how can I solve it ??
note that
I am running Cisco Prime Infrastructure 1.4.
I appreciate your support.
01-15-2014 04:21 AM
Yes ,this feature is not available till PI 2.0
not sure if we have anything in PI 2.1
Thanks-
Afroz
01-15-2014 05:20 AM
ok thanks alot.
kindly I want to ask for another issue.
after I configured the global mail setting on my cisco prime infrastructure (I set the ip of primery SMTP then sender and reciever parameters) then I press on test button to send a test mail but it not send ??
note that:
I made sure all services are running using (ncs status) command
I appreciate your kindly help
01-15-2014 05:23 AM
Kindly open a new thread..
will appricate ,if you mark this thread as resolve
thanks-
01-15-2014 05:42 AM
I oppened a new thread
https://supportforums.cisco.com/thread/2261374
I appreciate your kindly support.
