11-02-2018 11:56 AM
Need help in creating a template for setting up switch priority for a switch stack. See command below:
switch 1 priority 1
switch 2 priority 2
switch 3 priority 3
switch 4 priority 4
switch 5 priority 5
I created a CLI (User Defined template) using the above commands with spaces in between but when being deployed it is failing and looks like there's no space. Need a space in between because it is asking to confirm.
Thank you.
Solved! Go to Solution.
11-02-2018 01:42 PM
I was able to figure out how to do it. I tested the script I did below and it worked.
#INTERACTIVE
switch 1 priority 1<IQ>confirm<R>
#ENDS_INTERACTIVE
#INTERACTIVE
switch 2 priority 2<IQ>confirm<R>
#ENDS_INTERACTIVE
#INTERACTIVE
switch 3 priority 3<IQ>confirm<R>
#ENDS_INTERACTIVE
#INTERACTIVE
switch 4 priority 4<IQ>confirm<R>
#ENDS_INTERACTIVE
#INTERACTIVE
switch 5 priority 5<IQ>confirm<R>
#ENDS_INTERACTIVE
end
wr
11-02-2018 01:42 PM
#INTERACTIVE
#ENDS_INTERACTIVE
#INTERACTIVE
#ENDS_INTERACTIVE
#INTERACTIVE
#ENDS_INTERACTIVE
#INTERACTIVE
#ENDS_INTERACTIVE
#INTERACTIVE
#ENDS_INTERACTIVE
end
wr
11-02-2018 03:02 PM
Hope you aware higher priority will be elected as master.
11-02-2018 03:08 PM
I am. That's the reason why I am changing the priorities what the previous admin did and pushing to hundreds of devices that's why I need to have a script working.
Not only who is the master, standby master but also where the uplink is connected. Changing the priority to have the less impact.
11-02-2018 03:29 PM
ok just want to heads up that...generally sw1 we do high priory in general practice so checking are you doing right direction.
11-02-2018 10:35 PM
Yes, I have this problem too
11-03-2018 03:44 AM
what problem ?, suggest to open a new ticket with more information it easy to address each individual problem rather complicating the problem.
