Cisco Prime Infrastructure compliance - GET SN phones
dijix1990
Somebody know Can I use condition in the compliance with variable?
I thought that I can use these rules
1. Find name of the interfaces - command - show lldp neighbors and matches (Gi\d+\/\d+\/\d+|Gi\d+\/\d+|Fa\d+\/\d+)
2. Find SN via command - show lldp neighbors <1.1> detail and matches Serial number:([^\n]+)
<1.1> from rule 1
marce1000
   - Think best is to try ; normally that is not often used and chances that you will get a direct answer to
 the question are low. Also make sure to use the last release of Cisco Prime (3.10.5) certainly not versions
 that are very old ,
  M.
