Cisco Prime Infrastructure DNS problem
mfilser
Hi all.
I've a little problem with my PI 3.3
Some devices are properly displayed with the dns-name. Some not ...
The DNS-entries are correct. The ip domain-name is also defined.
Here is the Show running from the CLI
hostname PRIME01
ip domain-name XXXXXXX.YZ
interface GigabitEthernet 0
  ip address 10.0.0.12 255.255.255.0
  ipv6 address autoconfig
ip name-server 10.0.0.30 10.0.0.116 10.16.0.4
ip default-gateway 10.0.0.1
clock timezone CET
ntp server 10.250.0.45
username admin password hash. role admin
service sshd
repository NTM
  url ftp://10.0.0.49/
  user admin password hash
repository defaultRepo
  url disk:/defaultRepo
password-policy
  lower-case-required
  upper-case-required
  digit-required
  no-username
  disable-cisco-passwords
  min-password-length 6
logging localhost
logging loglevel 6
cdp timer 60
cdp holdtime 180
cdp run GigabitEthernet 0
icmp echo on
The DNS-Servers are accessible (ping, traceroute)
All ideas what the problem could be, are welcome :)
Markus
m.hegeraat
Prime infrastructure uses DNS to resolve names to IP addresses, but also does reverse lookup's where it tries to resolve and IP address to a name.
Check for the devices where you see issues, if it works both ways and adjust your DNS if it doesn't.
You can open a root shell and test with dig or nslookup
The DNS-Servers are working as DNS and also as Reverse-DNS.
I've tested this from the PI-Server and from several devices as well. It works.
Some other ideas?
Markus
Well, guys .... I've solved the problem by deleting the devices and a new add (manually) of them.
I don't know why .... but it works ...
Never the less, the main problem is not solved completely.
Viewing to the performance data dashboard (e.g. Top-N Server), the end-hosts are displayed by IP-Address.
I've enabled:
Administration > Settings > System Settings > Client and User > Client  > Lookup client host names from DNS server
Should I do additional things to display the names?
Markus
