Cisco Prime Infrastructure - failed to initialize DiscoveryController
Robert Saurer
I created a discovery job (ping sweep) under a virtual domain and when I run it as "root" user, the job immediately fails.
Error Message:
Is this unsupported?
The same discovery job also is seen in the ROOT virtual domain and runs successfully in the root domain.
Any advice?
The background is that the endcustomer doesn't want staff access to the root domain. They shall only have access to their virtual domains and shall be able to run discovery jobs for their IP ranges on demand.
Version : 3.7.0 [FIPS not Enabled]
Build : 3.7.0.0.159
Critical Fixes:
        PI 3.7 Update 03 ( 3.0.0 )
        PI 3.7.1 MaintenanceRelease ( 1.0.0 )
        PI 3.7.1 Update 02 ( 2.0.0 )
I have the same problem, did you find a solution?
Robert Saurer
No, unfortunately not. We still have an open TAC case with BU involvement.
