Cisco prime infrastructure Features & Technologies template
dijix1990
Hi I need a help I want to change some descriptions on my routers via  Features & Technologies CLI template
I try to use symbol
Like
int Vl100
des -E- ### Internet main channel
but CPI ignore it and try to install (Without ### Internet main channel)
int Vl100
des -E-
maybe I need to screen it
pieterh
In short: don't use "#" in a template!
I answered a similar question before
Prime Infrastructure CLI Templates - Cisco Community
with the reply below, unfortunately the link in that post does not work anymore,
but the statement about "#" as precessing a known keyword will still be valid !
the # has special meaning in CLI template. look at this example from the book
    #foreach ($interfaceName in $interfaceNameList)
      interface $interfaceName
      shutdown
   #end
so using it multiple times (used as a comment) you can expect some problems
CPI tries to match a "known keyword" following the #sign and on nomatch ignore the # and what follows.
edit: new link
Cisco Prime Infrastructure 3.10 User Guide - Create Templates to Automate Device Configuration Changes [Cisco Prime Infrastructure] - Cisco
and also:
Oh, inconvenient that we can't use any special symbols
