Cisco Prime Infrastructure has stopped to working
Plinio Brandao
Hi community,
We are facing some problems with our CPI 1.3. The software suddenly stopped responding. We already tried to restart the service and the machine without success.
The following message was shown when we tried to start NCS:
gn827cb/admin# application start NCS
Purging PurgeSAMPollerRecods
{Mon May 20 11:19:20 BRT 2013} ===================================================
{Mon May 20 11:19:20 BRT 2013} =========Issuing dbadmin -v start=================
{Mon May 20 11:19:21 BRT 2013} =======executing delete sql script sam_poller_jobs_cleanup.sql====
{Mon May 20 11:30:10 BRT 2013} ==========Issuing dbadmin -v stop=================
{Mon May 20 11:30:13 BRT 2013} ===================================================
Completed purging SAMPoller Records
Starting Network Control System...
This may take a few minutes...
Failure during Network Control System startup.  Check launchout.log for details.
start
gn827cb/admin#
We also got this message:
gn827cb/admin# sh application status NCS
Health Monitor is running, with an error.
initHealthMonitor(): can not start DB
Reporting Server is Stopped
Ftp Server is Stopped
Database server is stopped
Tftp Server is Stopped
Matlab Server is Stopped
NMS Server is stopped.
SAM Daemon is not running ...
DA Daemon is not running ...
Syslog Daemon is not running ...
status
gn827cb/admin#
Any idea how can I solve this?
I'm also trying to open a case with Cisco, but they ask me about SN, and I'm using a VM/OVA deployment. I don't know how to find it.
I also checked that we have a problem with space:
Checking Disk Space...
df -h output...
Filesystem            Size  Used Avail Use% Mounted on
/dev/mapper/smosvg-rootvol
                      3.8G  285M  3.4G   8% /
/dev/mapper/smosvg-storeddatavol
                      9.5G  151M  8.9G   2% /storeddata
/dev/mapper/smosvg-localdiskvol
                       29G  173M   27G   1% /localdisk
/dev/sda2              97M  5.6M   87M   7% /storedconfig
/dev/mapper/smosvg-home
                       93M  5.6M   83M   7% /home
/dev/mapper/smosvg-optvol
                      120G  119G     0 100% /opt
/dev/mapper/smosvg-varvol
                      3.8G  117M  3.5G   4% /var
/dev/mapper/smosvg-usrvol
                      6.6G  1.2G  5.1G  19% /usr
/dev/mapper/smosvg-tmpvol
                      1.9G   35M  1.8G   2% /tmp
/dev/mapper/smosvg-recvol
                       93M  5.6M   83M   7% /recovery
/dev/mapper/smosvg-altrootvol
                       93M  5.6M   83M   7% /altroot
/dev/sda1             485M   18M  442M   4% /boot
tmpfs                 3.9G     0  3.9G   0% /dev/shm
df -k output...
Filesystem           1K-blocks      Used Available Use% Mounted on
                       3967680    291476   3471404   8% /
                       9903432    153700   9238552   2% /storeddata
                      29741864    176224  28030460   1% /localdisk
/dev/sda2                99150      5688     88342   7% /storedconfig
                         95195      5657     84623   7% /home
                     125157140 124238476         0 100% /opt
                       3967680    119396   3643484   4% /var
                       6919612   1227320   5335124  19% /usr
                       1967952     35816   1830556   2% /tmp
                         95195      5664     84616   7% /recovery
                         95195      5664     84616   7% /altroot
/dev/sda1               495844     17643    452601   4% /boot
tmpfs                  4021724         0   4021724   0% /dev/shm
df -k output for / /usr /var /opt
Thank you in advance.
predrag2006
Since it is a virtual appliance just attach them show tech-support and this should be sufficient for them. Regarding the disk space usage what you can do is:
1) Enable root access if you haven't ("root_enable" command).
2) Enter root mode.
3) Execute "du -sh /opt/*" it will list directories inside /opt which are consuming your disk space. After just analyze or find out which directories and files are causing this filling up.
P.
Predrag Petrovic
Hi all,
I have error to my CPI 3.1
In my console ESXI:
/dev/mapper/smosvg-optvol 2376/256000 files 244058/1024000 blocks (check after next mount) [failed]
An error occured during the file system check
Need your help
Hi Mady
you can resolved this iussue?
 - You will need to fsck the corrupt filesystem manually : after entering the root password enter
                fsck -y /dev/mapper/smosvg-varvol
M.
-- Let everything happen to you
       Beauty and terror
      Just keep going
       No feeling is final
Reiner Maria Rilke (1899)
