Cisco Prime Infrastructure license register Issue
douedraogo
what are  the requirement to active prime infrastructure  license
Hello @douedraogo
What you mean by requirements?
 Basically you need to have the license file and load the file in:
Administration / Licenses and Software Updates / Licenses
-If I helped you somehow, please, rate it as useful.-
thanks you to reply, i want to know what can i do before to active license into prime infrastructure.
so i'm register the license PAK to www.cisco.com/go/license and upload the file into prime but my prime server ask me the operator center license.
There´s nothing to be done before. In all times I loaded license on Prime, I just got the file and upload via ADD bottom.
operator center license is the directory: Administration / Licenses and Software Updates / Licenses
i do this task: Administration / Licenses and Software Updates / Licenses
but after the system ask me operator center license
i have got the operator Base license in my PAK
