Cisco Prime Infrastructure mobile application
Mohamed Sayed
Dear all,
I need to download the mobile application for the PI and I donot find it ?
I need your help.
Christopher McGuyer
Hi Mohamed,
This is available on the Apple App Store.  I just checked the store from my iPhone and see them.  Try searching on "Cisco Prime" and you should see the Cisco Prime app as well as the Cisco Plug And Play app.
Cheers,
Chris
Christopher McGuyer
Hi Mohamed,
Cheers,
Chris
thanks alot
