Cisco Prime Infrastructure v2.1 - Delete device fails
dal
Level 3
Level 3
Hi.
I'm trying out PI, but I have come across an error.
I'm trying to delete a device (a WLC 5508), but I keep getting this error every time I try:
Delete Device(s) Failed: 172.29.254.6. Please see log for more information.
But there are about 200 log files in Prime, so does anyone know where I should be looking?
I had 2 similar controllers in Prime, the first one got deleted without problems. Strange.
Thanks.
AFROJ AHMAD
check these logs files ::
ifm_fault.log
ifm_inventory.log
inventory.log
Also if possible , reboot the server once and try to delete the device again.
Thanks-
Afroz
****Ratings Encourages Contributors ****
Thanks- Afroz [Do rate the useful post] ****Ratings Encourages Contributors ****
AFROJ AHMAD
ifm_fault.log
ifm_inventory.log
inventory.log
Thanks-
Afroz
Thank you, that helped.
I found what I needed in ifm_intentory.log
It seems there was a problem deleting the AP's associated with the WLC.
So I deleted the WLC only first, and the AP's next, and now it's gone.
One strange thing though: The WLC could be seen correctly under the Virtual Domain I added it in, but the AP's could only be see in the root Virtual Domain.
I will try to re-add it now, to see if they all end up in the right place this time.
Thank you for your help.
