Cisco Prime Infrastructure - view interfaces configuration
Ipefixe
Good morning all,
In my company, I have 25 stacks of Cisco 2960X switches (WS-C2960X-48FPD-L and WS-C2960X-48FPS-L), so with SFP+ and GigabitEthernet ports.
The nomenclature of the description of the ports is "Name of the connected equipment - Name of the physical outlet in the building". Many of these ports do not have the correct description or the description is not complete.
With my Cisco Prime Infrastructure server, I would like to be able to quickly display the configuration of all the interfaces of each switch, automatically (Job for example). I would also like to be able to sort the results by what I want to search (description, affected vlan, BPDU, portfast ...)
Could someone answer my query?
Thank you in advance,
Nicolas
0 Replies 0
