Cisco Prime Infrastrucutre 3.5
toma.nikolov96
I have a question about having two interfaces in a virtual CPI solution with both having default gateway.
In the setup process the default gateway is being set and it appears in the global configuration of CPI configuration.
If I add a new virtual NIC and set an IP address, is it possible to have another gateway or static route in order to make the second interface to communicate outside the local LAN segment.
Here is the example:
test-cpi/admin# show run
Generating configuration...
hostname test-cpi
ip domain-name test-cpi
interface GigabitEthernet 0
  ip address 192.168.175.19 255.255.255.0
  ipv6 address autoconfig
default gateway 192.168.175.1
test-cpi/admin# show interface
GigabitEthernet 0
  : flags=4163<UP,BROADCAST,RUNNING,MULTICAST>  mtu 1500
        inet 192.168.175.19  netmask 255.255.255.0  broadcast 192.168.175.255
        inet6 fe80::250:56ff:fea8:304a  prefixlen 64  scopeid 0x20<link>
        ether 00:50:56:a8:30:4a  txqueuelen 1000  (Ethernet)
        RX packets 352153  bytes 68125563 (64.9 MiB)
        RX errors 0  dropped 290  overruns 0  frame 0
        TX packets 15789  bytes 12861192 (12.2 MiB)
        TX errors 0  dropped 0 overruns 0  carrier 0  collisions 0
GigabitEthernet 1
        inet 10.10.10.10  netmask 255.255.255.0  broadcast 10.255.255.255
        inet6 fe80::250:56ff:feb6:685a  prefixlen 64  scopeid 0x20<link>
        ether 00:50:56:b6:68:5a  txqueuelen 1000  (Ethernet)
        RX packets 38897  bytes 2370632 (2.2 MiB)
        RX errors 0  dropped 0  overruns 0  frame 0
        TX packets 16  bytes 1296 (1.2 KiB)
lo: flags=73<UP,LOOPBACK,RUNNING>  mtu 65536
        inet 127.0.0.1  netmask 255.0.0.0
        inet6 ::1  prefixlen 128  scopeid 0x10<host>
        loop  txqueuelen 1000  (Local Loopback)
        RX packets 807262  bytes 503941806 (480.5 MiB)
        TX packets 807262  bytes 503941806 (480.5 MiB)
ade # ifconfig
eth0: flags=4163<UP,BROADCAST,RUNNING,MULTICAST>  mtu 1500
        RX packets 354505  bytes 68558957 (65.3 MiB)
        TX packets 15949  bytes 12885400 (12.2 MiB)
eth1: flags=4163<UP,BROADCAST,RUNNING,MULTICAST>  mtu 1500
        RX packets 38939  bytes 2374076 (2.2 MiB)
In the current example I want GigabitEthernet 1 to be able to communicate outside the 10.10.10.0/24 subnet.
If it is possible can anybody suggest how it is done?
Thank you in advance!
marce1000
 - You  may be able to configure  this at the linux-root level ; log on as admin via ssh -> shell -> sudo -s
 M.
