Cisco Prime Issues
jorogan
Frequent Visitor
Frequent Visitor
Good Day,
I'm facing 2 issues on POC regarding on Cisco Prime and CMX, ]
1. AP Status on Maps was grey-out or unreachable
2. Successfully import the Maps in CMX but doesn't shows in CMX.
Please help me, Thanks
superego
Level 6
Level 6
You only have imported the MAP to CMX.
You also have to configure NMSP for WLC and CMX to talk to each other.
Refer to:
https://mrncciew.com/2015/10/23/cisco-cmx-10-2-part-1/
***Please mark as an acceptable solution if this helped***
