Cisco Prime LMs 4.2.1 installation error
vivekkumarv
                   Dear ,
                    We are getting the below mentioned error while installling Cisco Prime LMS 4.2.1 evaluation version on WIndows 2008 Enterprise R2.
We tried installing on a high end VMware server .Prerequisites are all taken care by us.We are getting a LMS installation abort log saying that
Swap space is not configured properly even after increasing the Paging size to 32 GB.Our physicalmemory is 16 GB.Hard drive has 2 partitions,one is
35 GB and other is 200 GB.
Installation and Abort error logs attached.
-----Dependency Handler Error
ERROR: kls not found
ERROR: Component kls is not found.
dfm : contains: kls dfmdb epm nos tis ptm pm adapters dfmad dfmsd dfmgr dfmnm dfmz cfi fhs afd dps vgm
-----Dependency Handler Errors
Can any one help please.
2 Accepted Solutions
Vinod Arya
Seems you are trying to install LMS 4.2.1 directly. LMS 4.2.1 is an incremental patch to LMS 4.2 , hence it requires LMS 4.2 to be installed previosly.
The Path to be on LMS 4.2.1 is :
LMS 4.2 --> LMS 4.2.1
You can download LMS 4.2 from:
http://www.cisco.com/cisco/software/type.html?mdfid=284259296&flowid=31102&softwareid=280775102
-Thanks
Vinod
-Thanks Vinod **Rating Encourages contributors, and its really free. **
This is great! Ciscoworks releases are often confusing and users tend to make mistakes.
Please mark this thread answered to close this, if resloved.
-Thanks
Vinod
Vinod Arya
-Thanks
Vinod
Dear Vinod,
Thanks for quick support.
Yes.you are correct.We downloaded the base version 4.2 and installed .it is working fine now.
Regards.
Vivek Kumar.V
-Thanks
Vinod
