Cisco Prime LMS 4.2.2 discovery error
Roman Kizyma
I have installed Cisco Prime LMS 4.2.2 on my Windows Server 2008 R2 SP1 x64. All works fine but when I tried to run discovery processes I received error messages:
"Error in communicating with DCR Server. DCR Server may be down. Please start the  DCR Server and then start discovery."
or
Error
Error in communicating with DCR Server. For more details click  here.
DCR Server may be down. Please start the DCR Server and then  refresh the page
I have tried to do same things which described on discussion "https://supportforums.cisco.com/thread/2068640",
"https://supportforums.cisco.com/thread/2078081" and "https://supportforums.cisco.com/thread/2005058" but it didn't help me.
Could someone help me with it or provide me link where that problem was fixed.
Thank you.
jreekers
Level 4
Level 4
Hi Roman.
Are you seeing a NOSUCHMETHOD Exception in the cstm.log file?
-Joe
Thank you for replay.
I found resolution for my problem with TAC support.
That issue was fixed after reinstallation LMS with local administrator privilege. Previous  copy of LMS was installed without local administrator privilege.
Good and useful information for others in Forum!
Probably more helpful, if you could share, which error/log, led the solution.
-Thanks
-Thanks Vinod **Rating Encourages contributors, and its really free. **
Sorry, but I have removed log file. As I remember it was error related with MySQL database, some issue with connection to database.
