Cisco Prime LMS 4.2.3 PTT
YEN-HSI Lin
HI
While i upgrade lms 4.2 to 4.2.3,login the web.
it's show "server is capable for performance tuning Please enable PTT(Performance Tuning Tool) for better performance.Refer Online help for more details on PTT"
I reference the document,but in my cli no such command "rmeptt"
http://www.cisco.com/en/US/docs/net_mgmt/ciscoworks_lan_management_solution/4.2/user/guide/configuration/cwcli.html#wp1287118
Anyone can help??
mbilgrav
Level 3
Level 3
If you run SoftAppliance, the command is located here:
/opt/CSCOpx/bin/rmept/rmeptt.sh
I would say the path would be similar on a windows installations %NMSROOT%/CSCOpx/bin/rmept/rmeptt.bat or something llike that, but i am guessing.
From the Doc you provided, it states the PTT will select a profile if it can detect one - so let us assume the profile allready has been selected.
Why do you want to change the settings ?
mbilgrav
Level 3
Level 3
HI mbilgrav:
Thanks for your response.
I wnat to change the settings,because i use PTT setup Default,So while i upgrade LMS from 4.2 to 4.2.3,and login the Web GUI it's always show
After i change setup,it's ok
thanks for your help
BR
ok - i see what you mean - there is  a popup right after each login to the web GUI.
/root-ade rmept]# pwd
/root-ade rmept]# \. rmeptt.sh -list
The profiles that match the OS in this machine are:
Default-Linux.xml
perftune_Linux.xml
/etc/init.d/dmgtd stop
/root-ade rmept]# \. rmeptt.sh -apply
The profile matching the system configuration is: perftune_Linux.xml
Updated config line for configmanager.DcmaService
Updated config line for server.DmMain
Updated config line for server.ICServer
Updated the file :/opt/CSCOpx/objects/dmgt/dmgtd.conf successfully.
Update config line for -Xmx failed.
Updated config line for ConfigJobManager.heapsize=
Updated the file :/opt/CSCOpx/MDC/tomcat/webapps/rme/WEB-INF/classes/JobManager.properties successfully.
Updated config line for snmp.threads.min =
Updated config line for snmp.threads.max =
Updated the file :/opt/CSCOpx/MDC/tomcat/webapps/rme/WEB-INF/classes/com/cisco/nm/rmeng/inventory/ics/core/conf/ICSConf.properties successfully.
Updated config line for FILTER_THREADS=
Updated the file :/opt/CSCOpx/MDC/tomcat/webapps/rme/WEB-INF/classes/com/cisco/nm/rmeng/csc/data/Collector.properties successfully.
Updated config line for CDA_MIN_THREADS=
Updated the file :/opt/CSCOpx/MDC/tomcat/webapps/rme/WEB-INF/classes/com/cisco/nm/rmeng/inventory/cda/cda.properties successfully.
Updated config line for VM_HEAP_MIN =
Updated config line for VM_HEAP_MAX =
Updated the file :/opt/CSCOpx/MDC/tomcat/webapps/rme/WEB-INF/classes/com/cisco/nm/rmeng/cli/framework/heap.properties successfully.
Updated config line for ThreadPoolCount=
Updated the file :/opt/CSCOpx/MDC/tomcat/webapps/rme/WEB-INF/classes/com/cisco/nm/rmeng/inventory/dm/conf/dmApp.ini successfully.
CCR update for max_threads_for_config_fetch succeded.
CCR update for max_threads_for_config_operator succeded.
CCR update for no_of_threads succeded.
CCR update for CDLNumOfThreads succeded.
CCR update for max_db_connections succeded.
CCR update for ThreadCount succeded.
CCR update for DBConnectionCount succeded.
The current profile is updated as : perftune_Linux
The profile perftune_Linux has been successfully applied on this machine.
[servername/root-ade rmept]#
/etc/init.d/dmgtd start
