Cisco Prime LMS 4.2.5 Supported Devices - Where is the document/link?
Jerry Montgomery
Good evening, all,
Where is the supported devices for Cisco Prime LMS 4.2.4 and 4.2.5?
The below link has information related to Supported Device Tables for Cisco Prime 4.2 - 4.2.3.
However, no document that details the supported devices for Cisco Prime LMS 4.2.4 and 4.2.5 is listed.
http://www.cisco.com/c/en/us/support/cloud-systems-management/prime-lan-management-solution/products-device-support-tables-list.html
Thank you,
Jerry
Marvin Rhoads
That's odd - I'm pretty sure they used to be there.
If you have support, I'd suggest opening a TAC case and requesting the documents - I'd say it's a documentation "bug".
It's not nearly the same, but if you're looking for a specific device, sometimes you can find it in the readme of the individual device package. Those can be seen in the downloads page when you hover over a given package or from within your LMS under the software updates menu.
Yisong Xu
please go this link:
http://www.cisco.com/c/en/us/td/docs/net_mgmt/ciscoworks_lan_management_solution/4-2/device_support/table/lms42sdt.html
Allen A
Hi Jerry,
Here's the links:
4.2
4.2.1
http://www.cisco.com/c/en/us/td/docs/net_mgmt/ciscoworks_lan_management_solution/4-2-1/device_support/table/lms421sdt.html
4.2.2
http://www.cisco.com/c/en/us/td/docs/net_mgmt/ciscoworks_lan_management_solution/4-2-2/device_support/table/lms422sdt.html
4.2.3
http://www.cisco.com/c/en/us/td/docs/net_mgmt/ciscoworks_lan_management_solution/4-2-3/device_support/table/lms423sdt.html
4.2.4
Not available
4.2.5
http://www.cisco.com/c/en/us/td/docs/net_mgmt/ciscoworks_lan_management_solution/4-2-5/device_support/table/lms425sdt.html
I hope is not too late.
Allen A.
