cisco Prime LMS 4.2 browser hanging issue
kamallohiaji
Hi Team,
We have Cisco Prime 4.2 installed Windows 2008 R2 server, I am facing problem when I am going under Report>Fault & events or any other section, the browser gets stuck in loading page and become unresponsive. If I restrart the Daemon manager service it works fine for some time and again start giving problem in two or three hours time interval.
I also face the same problem when I go to Admin > Job browser window.
Does any one face the same problem,I have changed the host name of thserver using script and also generated new SSL certificate and I tried with diffrent browsers but problem is still persisting.
Any help on this would be highly appreciated.
Pls. check attached the log files.
Michel Hegeraat
Level 7
Level 7
You probably have to many jobs in the job log.
Go over here: Admin -> Network -> Purge Settings -> Config Job Purge Settings and run a purge job.
Then configure scheduled purging of jobs.
Then have a look at the other jobs then can be purged
Cheers,
Michel
