Cisco Prime LMS 4.2 using 55 % of the CPU
Michel Legare
I recently installed LMS 4.2 appliance and I noticed that the web administration page was really slow. I checked the CPU utilization in VMware and it was at 55%. Is this normal?
thanks
Michel
Duong Nguyen
4.2 seems to be a little bit faster then 4.1, however I too is experiencing slowness with 4.2.2.  Pages take forever to load up, sign in takes nearly 10 minutes.
I tried this
https://supportforums.cisco.com/thread/2137331
a. Open the properties file name “gs.properties” under the path   NMSROOT/MDC/tomcat/webapps/cwlms/WEB-INF/classes/com/cisco/nm/gs/ui
b. Update the field IS_DEFAULT_PAGE as “false”
c. Clear the browser cache and login-in(Daemon restart not required)
Still no luck
