Cisco Prime LMS Custom Reports
Rod.Blackie
Hi I wonder if anyone can help.
Using the custom properties and query expression section in LMS Prime 4.1 I would like to create a report that checks the movement of end nodes.
For example I need to know if PC A on switch A has moved to switch B in the last month. I need to try and track the (unauthorised) movement of PCs on my network?
Perhaps I'm looking in the wrong field?
Any help in creating this report would be apprecaited.
Rod
Duong Nguyen
Ciscoworks has its own custom properitary database.  You can create an ODBC connection to the data base and use excel, access, or sql management studio to create and develop custom reports.
