Cisco Prime LMS Design
CSCO10675262_2
I am trying to plan a design for multiple sites/zones for Cisco prime LMS. The scenario I have is as follows:
1. There are a total of 5 different buildings/zones. Do note this is within the same location however divided into multiple blocks/buildings
2. There are a total of 3 Cisco Prime LMS; 2 units for 2 of the builings/zones and the 3rd unit is the overview unit
3. There are no POE devices/802.1x requirements
I would like to check from a design point of view; what may possibly be used for the 3rd unit of the LMS which is used to monitor all devices. It is planned for the following:
1. To monitor all devices
2. To send traps on critical links failures/high cpu/utilization/etc...
3. To generate reports
Not too sure if there may be any useful administration on the 3rd unit/overview prime LMS?
Any suggestion is appreciated.
Thanks.
Marvin Rhoads
What's your impetus to roll out a multi-LMS design? Availability, scalability, or just organizational separation?
Taking on that level of complexity is typically justified only in the largest scale deployments. (5000 plus network devices) There is a Large Scale Deployment Guide Whitepaper that gives a good overview of how to do that.
If you only want organizational separation, you would be much better off using device groups and role-based access control to limit users to certain groups.
