Cisco Prime LMS system job - how do I stop them?
cwallin
Hello, I have run into a problem with system jobs.
I noticed that our automatic backup stopped working and the reason is that two system jobs is in the running state.
When I try to stop them I get this output:
Error:
Cannot stop job 1019.6718 because ERROR: Unable to suspend system jobs. Check log for more details.
I could probably resolve this with a restart of the deamon manager, but frankly Im a bit frustrated with how often I  need to restart the application to solve an issue.
Maybe someone know a way to stop a system job?
BR /Crille
AFROJ AHMAD
Hi Crille,
You can delete the this Job as below:
1. Make note of the job ID's that you want to delete.
2. Open a dos shell and go to NMSROOT    for e.g C:\Progra~1\CSCOpx\bin
3. Issue the command:
cwjava -cw NMSROOT com.cisco.nm.cmf.jrm.jobcli
replace above NMSROOT with actual root like C:\Progra~1\CSCOpx
3. It will take you to the Job CLI mode
4. Issue the command:
delete 1019 (the job ID you want delete).
5. Close all CiscoWorks browsers and issue the commands:
net stop crmdmgtd
net start crmdmgtd
6. Wait 15 minutes and log back in to CiscoWorks
Thanks-
Afroz
**Ratings Encourages Contributors***
Thanks- Afroz [Do rate the useful post] ****Ratings Encourages Contributors ****
Hi and thanks for your reply, I have since the original post tried a stop / start and it removes the running job. But after a while it comes back, and Im not sure removing the job is a good idea, as it is labeled as "Maintenace job" and is scheduled to run every hour. Maybe best to open a TAC case to figure out what is going on?
 1019.6722 MAINTENANCE_JOB Running Periodic Maintenance Job Every 1 hour(s), starting 20 Aug 2014, 11:27:00 CEST Running admin Aug 20 2014, 11:27:00
