Cisco Prime Network 4.2.2 LDAP Integration
lpolli
Hi.
I cannot integrate Cisco Prime Network v4.2.2 with LDAP AD with "sAMAccountName". But, i can integrate with CN. Let me explain.
We have a "sAMAccountName" with the value "XYZ12345". But, my CN is equal to "LUIZ POLLI".
When testing with user = CN, everything works fine, but when user = "sAMAccountName" fail. I don't know how to solve it.
Regards.
Marvin Rhoads
Have you setup the user policy to allow special characters (like a space) in the username?
Step 1 Select Admin > System > User Management > Local User Policy Setup.
The Local User Policy Setup page appears.
Step 2 Select Allow Special Characters in username to allow special characters in the username
http://www.cisco.com/c/en/us/td/docs/net_mgmt/ciscoworks_lan_management_solution/4-0/user/guide/admin/admin/security.html#wp1054687
Hi Marvin,
We have installed Cisco Prime Networks(CPN) version 4.2.2. We don't use CiscoWorks LMS.
Look, sAMAccountName is "XYZ12345" and CN is "LUIZ POLLI".
The sAMAccountName is set inside my CN. Because needs to be unique identifier for each user.
The LDAP DN is "OU=PRT Temp User,DC=local,DC=com". When pressed the "test connection" button shows me to type username and password. The username and password works fine with "LUIZ POLLI", but when type username equal to "XYZ12345" shows me failed. I don't know if Prime Network supports using sAMAccountName.
Ah Cisco Prime Network OK. Sorry for my confusion.
You won't find much if any expertise here on that as it is primarily used within the carrier space.
Your best bet for answers on it is to open a TAC case.
No problem.
Yes, the best solution is to open a TAC case.
Regards.
