Cisco Prime not Working
ggmeza1983
I have a VM with Cisco Prime 3.6, when o log via console (with admin user), the output of show application status NCS is as shown in the attached file, same for show disk (no problem as it shows)
I attach the ncs status (same errors like show application status NCS)
Do you have any idea what is the problem?
6 Replies 6
Mark Elsen
        - On what hardware or hypervisor version/environment are you using Prime ?
 M.
Hi, the VM is on Huawei Cloud, I don´t known on whtat Hypervisor version is mounted. If you have any idea how can i obatin taht information, pls let me known.
Thanks.
                          >I don´t know on what Hypervisor version is mounted.
 - This info is essential -> your Huawei Cloud (installation ) documentation or contact their support.
  These requirements apply : https://www.cisco.com/c/en/us/td/docs/net_mgmt/prime/infrastructure/3-6/quickstart/guide/bk_Cisco_Prime_Infrastructure_3_6_0_Quick_Start_guide.html#con_1070036
 M.
balaji.bandi
Is this new installation or working one giivng this error information ?
if the working one giving this information, then shutdown teh Prime and wait for 10-15min and start again and test it.
BB
Hi, thanks for you answer. It was working, i'll try with shutdown the prime for 15 min
keep us informed.
BB
