cisco prime upgrade issue
PI/admin# dir
Directory of disk:/
4519816219 Mar 31 2021 13:59:37 PI-Upgrade-31x_32x_33x_34x_to_3.7.0.0.159.tar.gz
20 Apr 01 2021 15:43:26 crash
4096 Apr 01 2021 15:26:02 defaultRepo/
4096 Apr 01 2021 16:37:15 ftp/
16384 Nov 18 2017 12:52:18 lost+found/
4096 Jan 15 2018 13:18:01 sftp/
4096 Jan 15 2018 13:04:06 ssh/
4096 Jan 15 2018 13:04:06 telnet/
4096 Apr 05 2021 13:51:33 tftp/
Usage for disk: filesystem
13741481984 bytes total used
165804236800 bytes free
189150580736 bytes available
PI/admin# ncs ha remove
HA removal not required because HA is not enabled in this server.
PI-SB/sbadmin# copy sftp://IPaddress/PI-Upgrade-3.4_to_3.6.0.0.172.tar.gz disk:/defaultRepo
Username:
Password:
% Error: Transfer failed
the upgrade file 4.2Gb and the defaultRepo only 4Gb
is there any way to increase the defaultRepo space?
marce1000
 - Examine defaultRepo's content and check if anything can be cleaned up , follow the guidelines in this document :
       https://www.cisco.com/c/en/us/support/docs/cloud-systems-management/prime-infrastructure/200720-Prime-Infrastructure-Troubleshooting-L.html
                  but substitute /opt with /defaultRepo or the full path to defaultRepo if not being in the root directory.
 M.
