Cisco products missing from "Leap Second Adjustment June 30" Cisco Guidance Portal
dam0c0nr0y
Cisco have setup a portal dedicated to the Leap Second Adjustment June 30 which is located here: http://www.cisco.com/web/about/doing_business/leap-second.html with the purpose of the portal being to "Provide information for our customers and partners on the global introduction of the 2015 leap second".
In the "Product Information" tab of the portal, Cisco have categorised their products as either "No Expected Impact" or have issued some “Release Notes” (bug notifications) for those Cisco devices which contain a known bug relating to the leap second adjustment.
However, there is no guidance provided for the following Cisco products
  1. Cisco Catalyst 3560-X Series Switches
  2. Cisco Catalyst 3750-X Series Switches
  3. Cisco Nexus 1110-X Cloud Services Platform (CSP)
Does anyone on this community know if Cisco are classifying the above products as "No Expected Impact"? or "Impacted"?
Damian
Hi.
It is actually under the No Expected Impect secion:
No Expected Impact
Catalyst 2000, 3000, 4000 series
Thanks sebastiaanslootweg. Yes, I also discovered the relevant section relating to the Nexus 1110-X platform - as per below:
According to the Cisco leap-second information portal product families "Cisco Nexus 1100 (CSP)" and "Cisco Nexus 1000v (KVM, Vmware, HyperV, VSG)" are both vulnerable to bug CSCus80369 which is categorised by Cisco as severe. This bug is identified as a resolved high-priority bugs in the Cisco Nexus 1000V release notes for 5.2(1)SV3(1.4)
