Cisco Router C921-4P configuration.
klukasik
Hello mates,
From few days I'm fighting with Cisco C921-4P configuration.
I just want connect ISP via WAN port , setup my Network (also wireless one) and connect rest devices (Access points, switches etc) to the rest Gigabit Ethernet LAN ports.
I connected to the Router via console port I can set ip address to specific interface (but If I set ip address to the wan port I can not set to lan porst). But just this gives me nothing. I take the instructions from documentation "basic Router configuration" (https://www.cisco.com/c/en/us/td/docs/routers/access/900/software/configuration/guide/900SCG/routconf.html) but all this won't help me either.
Please someone can hold my hand and guide me like I were a child I mean commend after commend?
with the changes marked in bold, you should get connectivity. Make sure your LAN hosts are connected on port 0 - 3, as I think ports 4 and 5 are the WAN ports:
Current configuration : 993 bytes
version 15.8
hostname movitech
boot-start-marker
boot-end-marker
no aaa new-model
memory-size iomem 25
ip domain name sshcisco.net
ip cef
no ipv6 cef
license udi pid C921-4P sn PSZ25461HC2
redundancy
--> ip dhcp excluded-address 192.168.100.1
--> ip dhcp pool LAN
--> network 192.168.100.0 255.255.255.0
--> default-router 192.168.100.1
--> dns-server 8.8.8.8
interface GigabitEthernet0
no ip address
interface GigabitEthernet1
no ip address
interface GigabitEthernet2
no ip address
interface GigabitEthernet3
no ip address
interface GigabitEthernet4
no ip address
duplex auto
speed auto
interface GigabitEthernet5
--> description WAN Interface
--> ip address dhcp
--> ip nat outside
duplex auto
speed auto
interface Vlan1
--> description LAN interface
--> ip address 192.168.100.1 255.255.255.0
--> ip nat inside
ip forward-protocol nd
no ip http server
no ip http secure-server
ip ssh version 2
--> ip nat inside source list 1 interface GigabitEthernet5 overload
--> access-list 1 permit 192.168.100.0 0.0.0.255
--> ip route 0.0.0.0 0.0.0.0 GigabitEthernet5 dhcp
control-plane
line con 0
line vty 0 4
login local
transport input ssh
scheduler allocate 20000 1000
end
7 Replies 7
can you post the configuration you currently have (the output of 'show run') ?
I reset router to the factory setting so right now it looks like this:
Building configuration...
Current configuration : 905 bytes
version 15.8
hostname Router
boot-start-marker
boot-end-marker
no aaa new-model
--More--
and what do you think?
I noticed that I didn't upload whole information.
version 15.8
hostname movitech
boot-start-marker
boot-end-marker
no aaa new-model
movitech(config)#do show running-config
version 15.8
hostname movitech
boot-start-marker
boot-end-marker
no aaa new-model
ip cef
no ipv6 cef
redundancy
no ip address
no ip address
no ip address
no ip address
ip address 192.168.100.2 255.255.255.0
duplex auto
speed auto
no ip address
shutdown
duplex auto
speed auto
interface Vlan1
no ip address
no ip http server
ip ssh version 2
control-plane
line con 0
line vty 0 4
login local
transport input ssh
end
version 15.8
hostname movitech
boot-start-marker
boot-end-marker
no aaa new-model
ip cef
no ipv6 cef
redundancy
no ip address
no ip address
no ip address
no ip address
no ip address
duplex auto
speed auto
--> ip address dhcp
--> ip nat outside
duplex auto
speed auto
interface Vlan1
--> ip nat inside
no ip http server
ip ssh version 2
control-plane
line con 0
line vty 0 4
login local
transport input ssh
end
after this lines "show run" looks like below. Now it gives me some random network name "Network 91" when I connect laptop to the lan port (like you said LAN 0-3, WAN 4-5) but still there is no internet, even when I connect isp rj45 cable to the wan port it's not even blinking.
Current configuration : 1455 bytes
! Last configuration change at 09:10:44 UTC Wed Sep 21 2022
version 15.8
hostname Router
boot-start-marker
boot-end-marker
no aaa new-model
ip dhcp pool LAN
dns-server 8.8.8.8
ip cef
no ipv6 cef
redundancy
no ip address
no ip address
no ip address
no ip address
no ip address
shutdown
duplex auto
speed auto
ip address dhcp
ip nat outside
ip virtual-reassembly in
shutdown
duplex auto
speed auto
interface Vlan1
ip nat inside
no ip http server
control-plane
line con 0
line vty 0 4
login
transport input none
end
Ok I find a problem (there was no "no shutdown" at gig 5 port). Thanks for answer and help. I have also 3 more questions:
1) There is an option to enable webUI for this router?
2) There is an option to change network name (from random "Network 91" to whatever I want)?
3) There is an option to setup WIFI?
