Cisco Router Model
bokayle123
Hello, I have a lab exercise regarding NAT. Can anyone tell me which router model in Packet Tracer has the following ports: Fa0/0 and Gig0/2?
@bokayle123
Usually the routers has either Fast or Giga interface. What you can do is install modules. You can use the RouterPT model and install the module  PT-ROUTER-NM-1CGE
M02@rt37
Hello @bokayle123
1841 Router is a common choice that offers a combination of Fast Ethernet and Gigabit Ethernet ports.
Power off the router and add the module card:
Power On the Router,, you will see the Giga interface
Best regards
As a side note, many of Cisco's small routers couldn't actually provide wire-speed throughput to their Ethernet ports.  An actual 1841, I recall, cannot provide 100 Mbps throughput let alone gig.  However, this, device performance, is usually a non issue for Packet Tracer.   I mention this because device performance in production networks is generally an important consideration.
