Cisco Secure ACS & UCP problems
walderhaug
I have ACS4.0 running on a W2003 server, which also have IIS6.0 running for UCP.
When I access the first page of UCP (login.htm) everything seems ok, but when I click on the "Login" button I get an error on the next page:
CGI Error
The specified CGI application misbehaved by not returning a complete set of HTTP headers.
Does anyone have a solution on this?
Thanks in advance
Tommy
wdrootz
Level 4
Level 4
As a resolution summary, to change it you can change the IIS settings:
Start-> Program-> Windows-> Microsoft Internet Information Server-> Internet service manager-> Default WEB site( stop it)
-In the machine select properties and change the port to 80.
Now you can start up essentials with:
http://
ernest617
I have the same error too.
Please help.
Thanks.
Ernest
I did find a solution on this in the security forum:
http://forums.cisco.com/eforum/servlet/NetProf?page=netprof&forum=Security&topic=AAA&CommCmd=MB%3Fcmd%3Ddisplay_location%26location%3D.1ddc0fa2
This works, even if I don't think it's the best solution from a security point of view.
Tommy
