09-04-2014 07:59 AM
hi all
i have very recently just started using cisco superrvisor desktop for our incoming calls.
i was woindering if it is possible to create a report of all calls received after 4pm by a agent? if you could explain this in baby steps i would appreciate this
thanks
michael
Solved! Go to Solution.
09-04-2014 10:42 AM
You would use the Historical Reporting tool which can be downloaded from the Contact Center Express server. From there you can create reports.
09-04-2014 10:11 PM
09-04-2014 10:42 AM
09-04-2014 10:11 PM
