Cisco Switch Log
IrfanKhan4904
Cisco Switch Model is cisco WS-C3750G-24PS (PowerPC405).
Following is the log of this switch. So anybody helps me to understand this?
02:56:26: %ILPOWER-5-IEEE_DISCONNECT: Interface Gi3/0/21: PD removed
02:56:33: %ILPOWER-7-DETECT: Interface Gi3/0/21: Power Device detected: IEEE PD
02:56:33: %ILPOWER-5-POWER_GRANTED: Interface Gi3/0/21: Power granted
02:56:41: %LINK-3-UPDOWN: Interface GigabitEthernet3/0/21, changed state to up
02:56:43: %LINEPROTO-5-UPDOWN: Line protocol on Interface GigabitEthernet3/0/21, changed state to up
02:57:02: %LINEPROTO-5-UPDOWN: Line protocol on Interface GigabitEthernet3/0/21, changed state to down
02:57:03: %LINK-3-UPDOWN: Interface GigabitEthernet3/0/21, changed state to down
02:57:06: %LINK-3-UPDOWN: Interface GigabitEthernet3/0/21, changed state to up
02:57:08: %LINEPROTO-5-UPDOWN: Line protocol on Interface GigabitEthernet3/0/21, changed state to up
03:05:09: %HARDWARE-2-THERMAL_WARNING: Temperature has reached warning threshold
03:09:36: %ILPOWER-7-DETECT: Interface Gi3/0/15: Power Device detected: IEEE PD
03:09:36: %ILPOWER-5-POWER_GRANTED: Interface Gi3/0/15: Power granted
03:09:41: %LINK-3-UPDOWN: Interface GigabitEthernet3/0/15, changed state to up
03:09:43: %LINEPROTO-5-UPDOWN: Line protocol on Interface GigabitEthernet3/0/15, changed state to up
03:10:02: %LINEPROTO-5-UPDOWN: Line protocol on Interface GigabitEthernet3/0/15, changed state to down
03:10:03: %LINK-3-UPDOWN: Interface GigabitEthernet3/0/15, changed state to down
03:10:06: %LINK-3-UPDOWN: Interface GigabitEthernet3/0/15, changed state to up
5 Replies 5
Mark Elsen
 - The devices connected at the subsequent interface(s) may experience problems and or are going up and down.
 M.
-- Let everything happen to you
       Beauty and terror
      Just keep going
       No feeling is final
Reiner Maria Rilke (1899)
Leo Laohoo
Post the complete output to the command "sh interface G3/0/15 controll".
NOTE:  Do not post screenshots.
show interfaces gigabitEthernet3/0/15 GigabitEthernet3/0/15 is up, line protocol is up (connected) Hardware is Gigabit Ethernet, address is 0026.5266.1e8f (bia 0026.5266.1e8f) Description: ****DORM-E1**** MTU 1500 bytes, BW 1000000 Kbit, DLY 10 usec, reliability 255/255, txload 1/255, rxload 1/255 Encapsulation ARPA, loopback not set Keepalive set (10 sec) Full-duplex, 1000Mb/s, media type is 10/100/1000BaseTX input flow-control is off, output flow-control is unsupported ARP type: ARPA, ARP Timeout 04:00:00 Last input never, output 00:00:00, output hang never Last clearing of "show interface" counters never Input queue: 0/75/0/0 (size/max/drops/flushes); Total output drops: 0 Queueing strategy: fifo Output queue: 0/40 (size/max) 30 second input rate 82000 bits/sec, 73 packets/sec 30 second output rate 1116000 bits/sec, 200 packets/sec 10094306 packets input, 3435942248 bytes, 0 no buffer Received 94893 broadcasts (0 multicast) 0 runts, 0 giants, 0 throttles 0 input errors, 0 CRC, 0 frame, 0 overrun, 0 ignored 0 watchdog, 82912 multicast, 17969 pause input 0 input packets with dribble condition detected 36324787 packets output, 3082363060 bytes, 0 underruns 0 output errors, 0 collisions, 1 interface resets 0 babbles, 0 late collision, 0 deferred 0 lost carrier, 0 no carrier, 0 PAUSE output 0 output buffer failures, 0 output buffers swapped out
What are those PED?
balaji.bandi
if you worried about this logs, look at below explanation and required further information what is the device connected along with controller information.
https://www.cisco.com/c/en/us/td/docs/switches/lan/catalyst3750/software/release/12-2_37_se/system/message/smg/msg_desc.html
BB
