Cisco switch stacking kit Compatibility?
eeebbunee
Level 5
Level 5
Does Cisco has a matrix document about stacking kit (tools)?
I was wondering if I can reuse the stacking tool for different product.
C3750X --- C9300L.
Leo Laohoo
3750X cannot be stacked with 3650/3850 or 9300/9300L because the physical stacking cable is different.
6 Replies 6
Seb Rupik
Hi there,
Not sure I have ever seen tools, they use thumb screws, you shouldn't tighten them any tighter then your fingers can muster.
As for the stacking cables, they are not interchangable.
cheers,
Seb.
Thank you for the quick response.
I would like to reuse only stacking tools that I am using for 3750 switches to 9300 switches.
Anyway stacking tools (cables) couldn't be made... Okay.
I appreciate your comment.!!
You can not stack these 2 models. and even you can not use the cables here.
BB
eeebbunee
Level 5
Level 5
Hello all,
Does Cisco has matrix for stacking tools? I was wondering if I can reuse the stacking tool.
3750X stacking tool to 9300. Is there anyone who ever tried before?
      - You can't mix these models in a single stack.
 M.
-- ' Listen to the wind, it talks
          Listen to the silence, it speaks
             Listen to your heart, it knows
Ganado Mucho (1809 to 1893 ) Navajo Indian
Leo Laohoo
