Cisco topology mapper
I am looking for something like cisco network assistant that can map my network etc. any good suggestions. it will how ever have to have better support for more switch models
thanks
balaji.bandi
check below one :
https://www.solarwinds.com/network-topology-mapper
BB
Hello, have you used or are using now Solarwinds NTM?
If so did you configure SNMPv3 so the tool would collect the internals of the switches to be used in the maps?
The tool finds all our switches but configuring SNMPv3 isn't working.
Keeps stating credential failed even though there the same credentials used in Prime and ISE.
ej
